16 servos with PCA9685 board for Arduino and Esp32 wroom
solozerouno
Has thanked: 2 times
Been thanked: 2 times
Post by solozerouno »
I would like to ask you to add a development board that can manage 16 servos based on the PCA9685 chip and uses the I2c connection that can be used on Arduino, ESP32 WROOM and similar boards. I already thank you if you can because it is a module already done with all the connections and I think that with Flocode 9 could be an economical way to manage 16 servos via I2c.
Thank you very much.
Solozerouno.
Has thanked: 647 times
Been thanked: 856 times
Re: 16 servos with PCA9685 board for Arduino and Esp32 wroom
Many thanks for the suggestion I've ordered a module so I can have a go at adding a component for it.
The PCA9685 is now available as a component under Outputs.
It seems to be working great here for me but let me know if you give it a go.
