VL53L0X library need.
seokgi
Has thanked: 8 times
Been thanked: 9 times
Post by seokgi »
Hi. Matrix guy.
I am going to use the VL53L0X for distance measurement. But there are many difficulties. Can you make a new library for me?
Please.
Thank you.
Has thanked: 647 times
Been thanked: 856 times
Re: VL53L0X library need.
Thanks for the suggestion I will see if I can get my hands on one and give it a go for you.
I've made a component to drive this now and I've got a sensor arriving later today. The library to drive this module is certainly extensive so hopefully I've implemented it all correctly. If all goes well then I'll do some testing and release the component as soon as it's working, hopefully later today.
Edit, Seems to be working so I've released the component on the update system.
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
Hello ,
What are the registers and value used in the VL53L0X1 component ?
like range, offset, SPEED, ACCURACY, ref...
thx for your prompt reply
Seb
