TCA9548A I2C expander for Arduino , ecc
solozerouno
Has thanked: 2 times
Been thanked: 2 times
Post by solozerouno »
It's possible to ask for the addition of a component like an I2C i/o expander with 8+8 pins the TCA 9548A is perfect with Arduino UNO , etc.
thanks a lot.
Solozerouno.
Has thanked: 647 times
Been thanked: 856 times
Re: TCA9548A I2C expander for Arduino , ecc
Many thanks for the suggestion, I've now got one on order and will have a go at creating a component for you.
This has now been added via the update system.
Here is an example of it in use.
I2C_Multiplex_Example.fcfx
(13.55 KiB) Downloaded 502 times
The multiplexer IC is connected directly to the microcontroller and up to 8 temp/humidity sensors are connected to the CH0-CH7 of the multiplexer.
