Error in Debuger
mehmet64
Has thanked: 8 times
Been thanked: 4 times
Error in Debuger
Post by mehmet64 »
when i lunch debuger somtimes system turn crash and send this message i attach it .....
Has thanked: 311 times
Been thanked: 479 times
Re: Error in Debuger
Are you using the latest v9.2 release? If not, please update and see if you get the same error with this new version.
Do you have any more information about this crash? E.g. does it happen immediately, or when attempting to run a specific command? Does the problem occur when single-stepping through the code?
It may also help if you post the project file so I can try to replicate the problem.
mehmet64
Post by mehmet64 »
Hello this is my project////when i RUN debugger program turn Crash and close
Zen.fcfx
(279.5 KiB) Downloaded 678 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi.
I would advise you to switch the watchdog off when debugging and also you need to make sure you clear the watchdog in code when using in the
real application.
mehmet64
Post by mehmet64 »
hi
in real aplication i dont have any problem but in debuger in program when i set a bareak point FLC get in crash and close without ask any question
I tried your program but could not replicate the error. What version of Flowcode are you using and are you running it in the English language or another language?
Also, if you can provide a simple project and steps to replicate the issue, it will be a lot easier for us to solve the problem.
mehmet64
Post by mehmet64 »
hi
this problem had a somtimes not any time
