Hello?
I'm working on a project using PIC18F47Q10.
ADC is not working.
https://www.flowcode.co.uk/mmforums/view ... 76&t=22120
I'm refer to this. AN0 works. AN1 does not work. C is so difficult.
I want to program ADC from icon.
please.
thank you.
ADC Not work PIC18F47Q10
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: ADC Not work PIC18F47Q10
Thanks for letting us know. I've found and fixed a problem which hopefully will improve things for you. If not then please can you post a simple project file showing the problem and I'll investigate further.
Thanks for your interest.
I solved this problem in the manual and the answer to the same problem in FC8. And I just updated the library. We will test it and report the results.
And I'll post how I solved it. And I'll post how I solved it. See the Read_VOL macro.
- Dog_Toilet_Washer1_ADC.fcfx
- (44.04 KiB) Downloaded 553 times
