does not show me the oscilloscope
Vatel20
Post by Vatel20 »
FC9 does not show me the oscilloscope .
Has thanked: 645 times
Been thanked: 703 times
Re: does not show me the oscilloscope
Hi, Vatel20.
If you go to Help, Licensing & View.
Has the Test & Debug component pack got a red X or is it active?
What happens when you select View oscilloscope?
Are you saying when the oscilloscope ion has an outline around it you can't see the oscilloscope window?
Vatel20
Post by Vatel20 »
The Test & Debug data pack is active.
the oscilloscope outline is active, does not show the oscilloscope window?
Have you tried selecting the Window Ribbon, then Default?
Vatel20
Post by Vatel20 »
Thank you medelec35 making the default window the oscilloscope worked.
You're welcome.
Rather than a bug, I believe the window was allowed by your PC to go out of monitor range.
Thanks for letting us know it's sorted.
