Have used the encoder with interrupt previously with no problem
However tried to use today in simulation in a new program but does not appear to be working ie sometimes it changes sometime not and then appears to freezes
So as a check I decided to revert back to your sample in wiki and got similar erratic results
Note the wiki appeared to work but stopped counting after 25 and froze
Can you please check that no changes this year have affect the encoder
Have included the wiki file i used
David
ENCODER
DAVIDJOINER
- Been thanked: 18 times
- Has thanked: 618 times
- Been thanked: 818 times
Re: ENCODER
Hi David,
Working well here. I noticed the sizes on the panel were a bit off so I've adjusted things slightly and hopefully it works better for you now.
Let us know how you're getting on.
DAVIDJOINER
Re: ENCODER
Thanks but still not working correctly
As before moving the knob up to around 25 to 28 works fine
But then often the knob freezes and does not increase further ie the knob stops moving
if i then move the knob downwards it moves down and then often freezes again but then i can increase it by 1 or 2 before it freezes again
If i run the debug multiple times sometimes it appears to fully work
Confusing
David
Confusing
David
Re: ENCODER
I've ran the simulation a handful of times here and can't manage to replicate the problem. Are you running version 9.2? If not then updating to this might help the problem.
DAVIDJOINER
Re: ENCODER
Ben
Yes running 9.2 could it get corrupted in anyway ?
Have checked windows performance whilst running it and no obvious windows problems
I wonder if any others in the forum could run it and see if they have similar problems
As hitting a brick wall until i can overcome it
David
David
