VL530L0X
Has thanked: 814 times
Been thanked: 203 times
VL530L0X
Post by jgu1 »
Hi!
I test the new VL530L0X component. Seem to work when I in Properties set the range to short. But If I switch to Long Range It doesn´t.
Am I doing something wrong in my testprogram? ;)
Br Jorgen
VL53L0X Test Uno.fcfx
(10.59 KiB) Downloaded 328 times
Has thanked: 595 times
Been thanked: 785 times
Re: VL530L0X
Hi Jorgen,
Thanks for letting us know.
Probably not you, the library for this device is extensive and very complex. I'll have a look but I don't hold much hope probably hundreds of lines of code to look through and compare, if it even worked in the original library.
I'll have a go and if I can't crack it then I might hide the long range property until we can have some time to sit and go through it with a comb.
Re: VL530L0X
Post by jgu1 »
Ok Ben, it is also a small device and ok with short distance. But everytime I see a new component and if possible I perform a test :D
