ECIO40P16 PULLUP RESISTORS
DAVIDJOINER
Been thanked: 18 times
Post by DAVIDJOINER »
I need to use the dspic internal pull up resistors on E0 E1 E2
can you advise me of the C code to achieve this
Best regards
David
Has thanked: 292 times
Been thanked: 458 times
Re: ECIO40P16 PULLUP RESISTORS
Looking at the datasheet for the dsPIC33EP256MU806, it looks like the CNPUE and CNPDE control the pull-ups and pull-downs for that chip.
To enable only the pull-ups on E0-2, I think the C code is:
CNPUE = 0x07;
CNPDE = 0x00;
DAVIDJOINER
Many thanks using CNPU works fine
David
