BMP280 wrong setting SDA and SCL for arduino in V9.2
Has thanked: 440 times
Been thanked: 603 times
Re: BMP280 wrong setting SDA and SCL for arduino in V9.2
Maybe try a baud rate of 100KHz instead of 400KHz, that's the baud rate of the working I2C sniffer and things like cable length could be having an impact and stopping 400KHz from working correctly.
rzeszurzeszu
Been thanked: 2 times
Post by rzeszurzeszu »
I checked but still without correct results.
Additionally if we would like to set custom baud rate than the cell to input the value is gray.
Any idea ?
rzeszurzeszu
Hello Guys,
still no solution ?
BR,
Has thanked: 512 times
Been thanked: 472 times
I have found my BMP280.
I will do some testing later today.
Hi rzeszurzeszu, I have found and fixed the issue.
I will let you know when the update is available.
Here are the results with my BMP280
BMP280 Results.png (9.21 KiB) Viewed 2458 times
Hi , rzeszurzeszu.
The updated component is now available via Updates.
