IOC port Select pins
pschoon
Been thanked: 3 times
Post by pschoon »
When using interrupt properties and selecting the IOC (interrupt on change Port) I always have to de-select all microcontroler pins.
When using a 100pin MCU these are a lot of pins. I only need one..
Can all these pins be de-selected instead of selected?
Thanks,
Patrick Schoon
seokgi
Has thanked: 8 times
Been thanked: 8 times
Re: IOC port Select pins
Post by seokgi »
I have a question too.
What does black green red mean?
Can I choose a rising edge or a falling edge?
thank you.
Has thanked: 616 times
Been thanked: 814 times
Yes a way to set/clear all pins in one go would be very handy. Thanks for the suggestion.
As for the pin colours, there should be a key that tells you what the colours mean.
Please note not all chips support the selectable IOC edge. We try and provide it where possible.
