Hi Guys
Is there a place I can go to get the flowcode esp32 Wroom pin layout. Say for example I'm trying to connect the PWM component and i go to channel 1 that says PORTB,4 now if i look at the data sheets for the Eesp32 there is no PORTB,4 so what pin do I connect it to? I have searched and tried to find the pin layout with no luck
ESP32 pin layout
jollybv
- Has thanked: 42 times
- Been thanked: 15 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: ESP32 pin layout
We have just used ports as that's what Flowcode is used to using.
We have used 32-bit ports to try and avoid segmentation and if you look under the hood this is also what the chip uses as it's port IO registers.
PortA 0 = GPIO 0
PortA 1 = GPIO 1
PortA 30 = GPIO 30
PortA 31 = GPIO 31
PortB 0 = GPIO32
PortB 1 = GPIO33
etc
PortA 0 = GPIO 0
PortA 1 = GPIO 1
PortA 30 = GPIO 30
PortA 31 = GPIO 31
PortB 0 = GPIO32
PortB 1 = GPIO33
etc
