Dual PWM
jimhook_uk1
Has thanked: 1 time
Been thanked: 3 times
Dual PWM
Post by jimhook_uk1 »
I'm trying to get 2 separate PWM channels with different average values, the attached simulates as expected but when I run on hardware both channels are the same - any suggestions greatly appreciated.
Jim
Clutch_Sig_Gen.fcfx
(12.88 KiB) Downloaded 344 times
Has thanked: 103 times
Been thanked: 302 times
Re: Dual PWM
Hi Jim,
You might not be getting the result you expect because you have the Period Overflow set to 181 but set PWM1 Duty to 191
i.e. greater than 181
jimhook_uk1
Has thanked: 1 time
Re: Dual PWM
Thanks Leigh, that fixed it.
