Backup settings and configurations, just in case...
miggarc
Has thanked: 7 times
Been thanked: 4 times
Post by miggarc »
Which flowcode folders/files do I need to copy so I have backup of its configurations and settings ?
In other words, which flowcode folders/files contain its configurations and settings ?
I'm asking this, just in case, if I need to reinstall, I don't need to be worried about making all the changes again, that feet my needs.
Its just all about (re)install and replace those files.
Thanks in advance,
Miguel
Many thanks in advance,
Miguel Garcia,
Electronic Systems Developer
Has thanked: 231 times
Been thanked: 392 times
Re: Backup settings and configurations, just in case...
The following registry location contains Flowcode v9 settings:
HKEY_CURRENT_USER\Software\MatrixTSL\FlowcodeV9
miggarc
Post by miggarc »
HI and thanks for your answer.
So... In case of flowcode (re)installation, if I want all my options and preferences like before, after reinstalling, it's all a mater of
delete this registry key and put there the one I backup.
I'm I right ?
Miguel
Miguel Garcia,
The installation of Flowcode does not change this registry setting, so reinstallation of Flowcode on the same PC should retain your existing settings. So if you are reinstalling to the same PC then I suggest you reinstall Flowcode and then re-activate your licence. There should be no need to copy your settings.
The only potential issues arise with licensing and hardware changes (e.g. some of the settings here relate to window positions). But reinstalling on the same PC with no licensing or monitor changes should be fine.
