License trial error FC9 only 4 days installed
camara3878
Post by camara3878 »
Only 4 days ago I installed CD 9 with the 30-day trial license and today it gives me the following error:
ERROR: NO USER DETECTED IN SESSION, PLEASE TRY RESTART FLOWCODE AND TRY ACCESS THIS SCREEN AGAIN.
I have a valid username. I have uninstalled it and reinstalled it.
Language changed to Japanese appears and command icons are shaded.
what's going on ?, thanks
Has thanked: 311 times
Been thanked: 479 times
Re: License trial error FC9 only 4 days installed
There should be no need to reinstall. Does the Licensing panel show the same message when you restart Flowcode?
And foreign languages are not currently implemented in Flowcode. We are working on a Chinese translation, but there are no plans for Japanese. The language option in Global Options should currently be disabled. Can you please give more details on what you are seeing.
camara3878
Here is a screenshot of all errors attach:
license not trial apppear _ license error _ lenguaje chinese _ shadow commands
The Chinese characters in the disabled Language box in Global Options screen is normal.
Does the "no user detected" message appear when you restart Flowcode? Just close Flowcode and then start it from the Windows 'Start' menu. Do not open a project. Instead, select "Licensing...Licensing" from the 'Home" menu.
The Command Icons are disabled when your project is simulating. If you select "Debug...Stop" then the icons will be available again.
camara3878
When FC9 starts it selects license and it gives me the following error mentioned above:
Have you followed the instructions here?
viewtopic.php?p=71#p71
camara3878
yes, i did and it worked for 4 days, then it failed
There may be an issue with your licence. My colleague is looking into this and we will get back to you soon.
camara3878
I'm waiting, if you need something let me know thanks
camara3878
if it is useful to you I use windows 7 32 bits
