I get this message although I have installed everything freshly
I just can't get any further.
I probably haven't found everything in the forum yet and tried it out.
Please have a look at it
Greetings
Target folder: C:\Users\uwe\Documents\Daten\Matrix
Source name: C:\Users\uwe\Documents\Daten\Matrix\dstike uhr.fcfx
Title:
Description:
Device: ESP.ESP32.ESP32
Generated by: Flowcode v9.2.0.33
Date: Monday, September 27, 2021 15:00:33
Users: 1
Registriert für: SpeedPic32 (24146314)
Lizenzschlüssel:UCCVMA
NICHT FÜR KOMMERZiELLE ANWENDUNGEN
https://www.flowcode.co.uk
Start des Compilers...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat "C:\Users\uwe\Desktop\esp-idf\" "dstike uhr" "C:\Users\uwe\Documents\Daten\Matrix\" esp32s_sdkconfig
C:\Users\uwe\Documents\Daten\Matrix>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D795899827D9F76D89626FBC8B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EE6FE0BB589D1229A5E37B217FF86DBD72A01B8FBC49BE02BFA3608A0B0CE69F969622A912E6E6A2FB
C:\Users\uwe\Documents\Daten\Matrix>REM REVISION: 4.0
C:\Users\uwe\Documents\Daten\Matrix>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
C:\Users\uwe\Documents\Daten\Matrix>REM DATE: 29\03\2021
C:\Users\uwe\Documents\Daten\Matrix>REM DIR: FCD\ESP\Batch\esp32_build.bat
Building dstike uhr ...
Setting IDF_PATH: C:\Users\uwe\Desktop\esp-idf
Adding ESP-IDF tools to PATH...
C:\Users\uwe\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\Users\uwe\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\Users\uwe\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\Users\uwe\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\Users\uwe\.espressif\tools\cmake\3.13.4\bin
C:\Users\uwe\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin
C:\Users\uwe\.espressif\tools\ninja\1.9.0\
C:\Users\uwe\.espressif\tools\idf-exe\1.0.1\
C:\Users\uwe\.espressif\tools\ccache\3.7\
C:\Users\uwe\.espressif\python_env\idf4.1_py3.7_env\Scripts
C:\Users\uwe\Desktop\esp-idf\tools
Python requirements from C:\Users\uwe\Desktop\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
[0/1] Re-running CMake...
FAILED: build.ninja
C:\Users\uwe\.espressif\tools\cmake\3.16.4\bin\cmake.exe -SC:\Users\uwe\Documents\Daten\Matrix\dstike_uhr -BC:\Users\uwe\Documents\Daten\Matrix\dstike_uhr\build
CreateProcess failed: The system cannot find the file specified.
ninja: error: rebuilding 'build.ninja': subcommand failed
Running ninja in directory c:\users\uwe\documents\daten\matrix\dstike_uhr\build
Executing "ninja all"...
ninja failed with exit code 1
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat Hat den Fehlercode 0x1 gemeldet
Autoclose turned off
BEENDET
ESP32 FAILED: build.ninja
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
- Has thanked: 103 times
- Been thanked: 302 times
Re: ESP32 FAILED: build.ninja
Some ideas ...
Are there any non-ASCII characters in the project path? Such as in the user name?
If not, could you try running the ESP-IDF Command Prompt (that should be on your desktop)
Then change directory (cd) to the project directory
e.g.
Then type
and see what that does
To capture the output (for posting) type
Some ideas ...
e.g.
cd "c:\users\uwe\documents\daten\matrix\dstike_uhr"Code: Select all
idf.py buildTo capture the output (for posting) type
idf.py build > logfile.txt
