I want to make a component that uses a property and for this property I ticked "Generate a define for the property". When compiled into C code, this property appears in quotation marks. How do I remove quotes when compiling to C code?
OlegKRS
- Been thanked: 3 times
- 0303.jpg (43.15 KiB) Viewed 7161 times
- 0202.jpg (50.1 KiB) Viewed 7161 times
- 0101.jpg (65.66 KiB) Viewed 7161 times
- Has thanked: 649 times
- Been thanked: 856 times
Re: Generate a define for the property
I've created a demo for you where I remove the quote marks using an Compile -> AddProperty event macro.
Hopefully it should do everything you need it to do.
Results in this being generated in the C code.
#define MX_ENCODERKF_DEMO_0 portc
