ESP 32 Quad encoder
Alan_37
Has thanked: 57 times
Been thanked: 28 times
ESP 32 Quad encoder
Post by Alan_37 »
Hi , I am trying to connect a quad encoder to esp32
but just by putting the enable icon will not compile I have tried to use
many pins it does not seem to be a GPIO selection problem .
AC_Tester.msg.txt
(17.09 KiB) Downloaded 471 times
AC_Tester.fcfx
(15.11 KiB) Downloaded 531 times
Has thanked: 110 times
Been thanked: 302 times
Re: ESP 32 Quad encoder
I've done a fix for the ESP32 Quad encoder errors,
I will ask Ben to push it out on the update system
Alan_37
Post by Alan_37 »
Hi LeighM , I will test and let you know
Thanks very much for your help.
Alan_37
Post by Alan_37 »
Hi LeighM,
Just tested the quad encoder on the esp32 and it is working fine now.
Thanks again for your help.
