Hi everyone,
Does FC support Internal Can BUS on ESP32? The FC component shows... but does it work?
Cheers,
R
ESP32 Internal CAN Bus Support
unity-control
- Has thanked: 23 times
- Been thanked: 11 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: ESP32 Internal CAN Bus Support
Yes it should be working, I'm not sure if it's been tested but there is certainly code there to drive the internal CAN peripheral.
unity-control
Many thanks Ben for this,
Will give a try to see if the interface works at all... Do you think RX CAN Interrupt can be implemented in Flowcode?
Thanks,
R
Thanks,
R
