esp32 display analog input in webpage
jancuaucamp
Has thanked: 1 time
Post by jancuaucamp »
Good day.
Im trying to get an analog input on wroom 32 esp and sent to html webpage.
All the examples I found sent is to app developer and not a webpage.
In the video the person say there is some examples in the wiki,I cant find it .
Does anyone have a example to display a variable to an html webpage
Has thanked: 627 times
Been thanked: 833 times
Re: esp32 display analog input in webpage
Here's a quick example that hopefully should help to show you the way.
ESP_Webpage.fcfx
(15.17 KiB) Downloaded 599 times
The outgoing substitution is referenced in the HTML code using the %0 text.
jancuaucamp
Has thanked: 1 time
Thanks ,That helped me alot.
Any change of an example how to recieve from webpage ?
Has thanked: 752 times
Been thanked: 814 times
Thanks, Ben.
It works great.
The only downside is the webpage will require refreshing if the ADC changes value.
There is a simple way around this.
To get the webpage to update every 5 seconds for example.
Within HTML Page 1 of Web Server properties add
<meta http-equiv="refresh" content="5" >
So you will have:
<html>
<body>
<h1>Flowcode Webserver</h1>
Webpage Created by Flowcode Webserver.<br />
ADC Value = %0.<br />
<a href="page2.htm">Click here for page2.</a>
</body>
</html>
The example here shows how to pass data back in using a standard HTML form.
https://www.flowcode.co.uk/forums/viewt ... f=10&t=634
Or you can do it in a more static way just using say link URLs.
for example this would pass the following in values 0="100", 1="abcd"
<a href="index.htm?0=100&1=abcd" >Test Link</a>
Has thanked: 245 times
Been thanked: 256 times
Hi to All
Webserver from Flowcode are working fine.
It's possible to read the page (values) on Windows, Android or iOS via Explorer.
What about an additional comand for the App Developper like "GET Value from Flowcode Web-Server"
Then you can also access the web server with the App Developper. Just read the page and extract the analog value.
That would be a nice addition command.
So it would be easy to query values with a time control in the Appdevelopper and to save them very easily in a log file.
And the convenience of the Flowcode web server remains
