Menus become unavailable [FIXED]
Has thanked: 292 times
Been thanked: 458 times
A minor bug has been identified which causes some strange behaviour, such as:
  • Menus and the ribbon becoming inoperable
  • Flowcode unable to be minimised or closed
  • Projects cannot be edited
This can happen when the user clicks on certain Flowcode windows very close to the window frame border (within 1 pixel of the border!). The following windows are known to exhibit this problem:
  • Forums
  • Wiki (Help and resources)
  • Licensing (Licensing and account)
A fix for this will be available when the next core update is released.
The simplest way to avoid this issue is to be aware of it and avoid mouse-clicks near the edge of these windows. If you encounter this problem and need to save your work, then use the Cntl-S shortcut (to save). To close Flowcode if you have this problem, right-click on the Flowcode icon on your Windows taskbar and select "Close Window".
