Address of variables
Osta
Has thanked: 1 time
Been thanked: 5 times
Post by Osta »
Hey!
Tell me how to find out the address of the declared variables?
Thanks!
Has thanked: 163 times
Been thanked: 960 times
Re: Address of variables
Post by mnfisher »
Hi Osta,
You need to use a little bit of C. Since FC doesn't have an address type - use an int large enough to hold the address (so 16bit or 32 bit)
In a C block
FCL_ADDR = &FCV_VARNAME;
Where addr is defined as a local variable - and varname a global - note that FC capitalises the variable name and adds FCL (local) or FCV (global).
Note that to read or write to the address you'll also need to use some C:
Osta
Has thanked: 1 time
Post by Osta »
Thanks Martin!
Got it.
Regards Osta.
Has thanked: 724 times
Been thanked: 783 times
There is an alternative method.
When you compile there are various files created.
For PIC if you look in the .sym file and search (using ctrl F) for your variable, the stored address is shown in hex
The format is _FCV_YOURVARIABLE (for global) or _FCL_YOURVARIABLE (For local).
Stored address.png (11.9 KiB) Viewed 4752 times
Depending on the side of the variable using more than one address could be used.
Both the above are bytes so only one location each is used.
with integers, it will be two, etc.
I'm not sure about AVR.
Osta
Has thanked: 1 time
Post by Osta »
Thank you so much!!!!
