LED Matrix (Serial) (Outputs: LEDs), Author: Matrix Ltd
Sergejs
Has thanked: 75 times
Been thanked: 5 times
Post by Sergejs »
How can I get it? Never see it for sale. Is this LED Matrix available in this world???
Has thanked: 292 times
Been thanked: 458 times
Re: LED Matrix (Serial) (Outputs: LEDs), Author: Matrix Ltd
I assume this product must be from a different company called Matrix? Or are you referring to a component in Flowcode?
Has thanked: 616 times
Been thanked: 814 times
THe LED Matrix serial component allows you to create a LED display using octal buffer ICs.
The schematics and examples are available from here.
https://www.flowcode.co.uk/wiki/index.p ... uts:_LEDs)
The parrallel version is also similar but takes 8 outputs and can drive 8 leds in one go and so is a bit faster to drive at the cost of IO pins.
Thanks, Ben. I was thrown by the "Matrix Ltd" company and I think there are similar-named companies that do manufacture dot-matrix displays.
