I am trying to run some c code within the project and have even tried to example in the help. But it does not run or do anything. Do I need another license? or is there a bug?
Nigel
C Code not running/working
ntuohy
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Re: C Code not running/working
Hi ,
There can be 1000 reason why its not working ,Please do as normal people and post your FC chart with some explanation of the error you are getting,
We do not have a glass ball to see what you are doing
This is the example code from the help (?) on how to use the c code
hope that helps
Nigel
hope that helps
Nigel
- test c code.fcfx
- (7.24 KiB) Downloaded 448 times
