Flowcode ARM license activation problem. [Solved]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Post by Sasi »
Hello Matrix Team,
I sent an email about an ARM license issue. I would like to know if it has arrived.
Sasi
AlfieD
Has thanked: 11 times
Been thanked: 5 times
Re: Flowcode ARM license activation problem.
Post by AlfieD »
Hi Sasi,
Cant seem to find any emails from you.
Please email me: alfie.dobson@matrixtsl.com
Sasi
Post by Sasi »
Hi Alfie,
I wrote an email about the problem and sent it to you.
Thanks for the help,
Sasi
Sasi
Post by Sasi »
This is interesting .
In fact, a new user has to pay £ 60 for it, not £ 35.
Update:
It has already been repaired.
Sasi
Post by Sasi »
Hi Alfie,
Unfortunately, there is still a problem with the ARM license.
I don't have access yet.
Can you help me?
Sasi
Post by Sasi »
Hello Matrix Team,
Maybe you have an idea how I could activate my ARM license?
Sasi
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi ,
Have you manually added the key you received and then manually activate the license ?
Sasi
Post by Sasi »
Hi Peter,
Yes, I also tried offline activation, but the license is still unusable.
This is still the case:
Sasi
p.erasmus
Post by p.erasmus »
Hi Sasi.
Just to make sure did you go to licenseing >> Licensing and add the key you received
as below if you select add key a window will open that you can enter your key into .
When that is done you need to go to Licensing >> Manage
then a window will open similar to this one with a tab Activate my license you need to go to that tab and activate the key with your Flowcode MATRIX account details
If you have done this and it still does not work the you need to conatct Alfie Dobson by email
:D
Hope you come right :D
Sasi
Post by Sasi »
Hello Peter,
Thank you for the advices
Unfortunately, the key is already inactive.
I've already corresponded with Mr. Alfie Dobson.
However, something has changed:
Licensing and account.jpg (36.52 KiB) Viewed 11373 times
Maybe I got it as compensation instead of the ARM license? :lol:
Or is there a more serious problem with the licensing system? :shock:
Hmmm!
