Good day,
Can someone please help me with code to enable internal pullup resistors on arduino uno in Flowcode.
I tried numerous different codes without success.
arduino uno Internal_Pullup enable
jancuaucamp
- Has thanked: 1 time
- Has thanked: 717 times
- Been thanked: 777 times
Re: arduino uno Internal_Pullup enable
Hi jancuaucamp.
The easiest way is to set the input you want the weak pullup on, to an output high.
Then change it back to an input.
The weak pullup should then be enabled.
- Has thanked: 160 times
- Been thanked: 950 times
There is a macro at
https://www.flowcode.co.uk/forums/viewt ... lit=pullup
that does the job too...
