The examples for the Quad Encoder (Test / Timer / IOC) seem to have a problem in that the encoder is not displayed in the 3D panel. It seems to be invisible. You can actually find it if you "search around" but it remains invisible.
Dragging an encoder into the panel is fine, it's just the examples that appear to have an issue.
Any ideas?
Quad encoder example issue
- Has thanked: 444 times
- Been thanked: 665 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: Quad encoder example issue
Hi.
A majority of the components are now 2D only.
That means if they were on 3D then they will appear invisible.
They will need to be dragged from the 3D panel to the 2D panel.
The easiest way is to hold the left mouse button down, swipe around the panel to highlight the components, then drag to the 2D panel.
Hi Martin
I wasn't aware of that.
Many thanks as always, you are a real font of knowledge.
You're welcome.
There are also plans to update existing examples and add new ones.
With the addition of wiki being updated, there is a lot going on behind the scenes.
