PWM does not work correctly
Osta
Has thanked: 1 time
Been thanked: 5 times
Post by Osta »
Hello everyone!
I use Attiny44 , Flowcode 9.2.
In the emulator, it works true and in Proteus and iron works not right!
Examples of work apply.
Proteus
Proteus
Flowcode
Flowcode
BG.fcfx
Proj
(10.53 KiB) Downloaded 279 times
Has thanked: 717 times
Been thanked: 778 times
Re: PWM does not work correctly
Hi, I don't have the Attiny44, so I won't be able to help much.
Does the hardware match the simulation or you have not tried it on hardware yet?
Can you try the one-second flasher test on your hardware to make sure the hardware is running at the correct speed?
Osta
Has thanked: 1 time
Post by Osta »
I made an order for attiny 44
When I get her then I can check.
Osta
Has thanked: 1 time
Post by Osta »
The delay in one second in Proteus was confirmed.
But PWM does not work right!
BG.fcfx
(11.1 KiB) Downloaded 264 times
I have just looked into this.
When you compile you will see a warning:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\AVR\AVR_CAL_PWM.c:495:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1" [-Wcpp]
Therefore, to get a PWM 50% duty cycle you need to set the duty to 127.
Unfortunately, that is the disadvantage of AVR.
Osta
Has thanked: 1 time
Post by Osta »
Many thanks!
With gratitude Osta.
As limited PWM is caused by the limitations of AVR, I have moved topic from the bugs section.
If you believe this is resolved can please add [Resolved] to the start of your subject.
