ESP32 WROOM 32 WiFi signal strength - Flowcode V9
wardelder
Post by wardelder »
Not sure I am correct, but when I run a WiFi Scan then do a ReadSignalStrengthFromScan, I get a number that is way off. If I subtract this number from 256, I get a very close reading to what my Android shows. For example, if I place an AP right beside the ESP32, I get a signal strength of 249. When I subtract this value from 256 it shows 7db (- 7db but the ReadSignalStrengthFromScan does not return negative numbers so you have to add the '-' sign)
So, it is working very well if I subtract from 256. Am I missing something?
V9_ESP32_WiFiScan.fcfx
(19.55 KiB) Downloaded 523 times
Has thanked: 633 times
Been thanked: 837 times
Re: ESP32 WROOM 32 WiFi signal strength - Flowcode V9
Many thanks for letting us know could be we are just returning what the espressif library provides. I'll investigate this for you and see if we can return a better value.
Hopefully should be all fixed for you now via a component update.
