Use of internal PIC timer functions
jan.didden
Has thanked: 20 times
Been thanked: 12 times
Post by jan.didden »
On FC9, do I need to purchase the Storage library to use a PICs internal timers?
Jan Didden
Linear Audio
Has thanked: 707 times
Been thanked: 768 times
Re: Use of internal PIC timer functions
Hi Jan.
If you are referring to timer interrupts, they don't require any library purchases.
If you want to know what's in each pack this is the first place to look.
Edit:
From reading the post on the Matrixtls forums, do you have a v5 example of what you would like to achieve?
Just as reminder.
The OSCCON within a C code block sets the internal oscillator to run at the correct speed.
The clock speed within project options sets up components with delays to run at the correct delay time.
