A minor bug...
I hit Ctrl+N (instead of Ctrl+M) - and it brings up the 'Flowcode has encountered a problem from which it is unable to recover' dialog box...
Clicking Okay - sends it away (with no apparent ill effects) - but it seems slightly unusual.
This on a fresh install and on an old install too - and on an empty/non-empty project.
- Has thanked: 177 times
- Been thanked: 1026 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: Flowcode has encountered a problem
Thanks Martin,
Good find I've replicated it here, presumable it's a keyboard shortcut thet no longer links to the function correctly.
- Has thanked: 311 times
- Been thanked: 479 times
Thanks, Martin. I've had a look and the Ctrl-N is used to create a new project. But in v9 this was changed from a simple menu function to working via what is called the "backstage view" - the special page that is shown when "File" is clicked on the menu.
The error can safely be ignored, and I will remove or replace the Ctrl-N functionality for future Flowcode versions.
