listing pins / ports used in a project against each component
DAVIDJOINER
Been thanked: 18 times
Post by DAVIDJOINER »
Is it easy to list the pins / ports being used by each component and dump to excel or into the project report
ie coms channel 1 rx b0
coms channel 1 tx b1
similarly for the other components
This i believe would be very useful and would also flag up any pins potentially being used by more than one component etc
i realise you can go into each component separately and look but can be rather long winded if using many components
Any ideas
David
Has thanked: 269 times
Been thanked: 442 times
Re: listing pins / ports used in a project against each component
Thanks, David. Good idea.
I will add a new section to the project exporter to list the properties of all components.
DAVIDJOINER
Thats sounds ideal
Many thanks
David
