Pic18f4525 & Ii9341 Advice!
Has thanked: 760 times
Been thanked: 188 times
Post by jgu1 »
Hi!
I am trying to test the speed on some device with Ili9341, and as here a Pic18f4525. Work fine, and nice with the new possibilities with font :D
But it is a little slow and wish to find a device wich can speed it up :lol: My question:
1. Have I set the config for max speed ?
2. I see it is possible to use 40mHz xtal at the Pic184525, if I buy one and use 40mHz, will this speed up? ( a lot ).
3. Alternativ, use another device which one should I choose? Prefer leaded.
4. I have made a test with a NucleoF410 wich is the fastest., but to big to build in my box.
5. Will a parallel display be faster and does it work in FC9?
I have tryed with the ESP32, but it will not work.
Lot of question, hope some have a hint. Please.
And happy New year!
Br Jorgen.
Ili9341Pic4525.fcfx
(14.37 KiB) Downloaded 482 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Pic18f4525 & Ii9341 Advice!
Post by p.erasmus »
Hi Jorgen,
Use a PIC18F45K22 or K80 these devices run at 64 Mhz (16Mhz XT and 4 x PLL = 64Mhz)or similar PIC26K22 or K80 which is the 28 pin package
if you really want to use GLCD etc then use a PIC24 series running at 140Mhz they are available in very small packages
:D
Post by jgu1 »
Hi P. erasmus!
Thank you for your advice, I will emediately order a couple. :D
Happy New year!
Br Jorgen
