ESP32 ERROR COMPILER
max.tisc
Been thanked: 10 times
Post by max.tisc »
Hello Team
I have a problem with the compilation of the ESP32, in the compilation phase from error 0x1 and does not program the card, compiling the blink program does not give the error and everything works correctly, looking at the 2 generated reports you see an error at point [2 / 6] what can it depend on? Originally the program was written for arduino 2560 and worked well, I wanted to pass it on ESP32 to use the WIFI part, and that should also be much more performing
thank you
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat  "C:\Users\Max\Desktop\esp-idf-2\" "FC9_ESP32_AS6040" "C:\Users\Max\Dropbox\fc9\" esp32s_sdkconfig
C:\Users\Max\Dropbox\fc9>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D795899827D9F76D89626FBC8B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EE6FE0BB589D1229A5E37B217FF86DBD72A01B8FBC49BE02BFA3608A0B0CE69F969622A912E6E6A2FB
C:\Users\Max\Dropbox\fc9>REM REVISION: 4.0
C:\Users\Max\Dropbox\fc9>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
C:\Users\Max\Dropbox\fc9>REM DATE: 29\03\2021
C:\Users\Max\Dropbox\fc9>REM DIR: FCD\ESP\Batch\esp32_build.bat
Building FC9_ESP32_AS6040 ...
Setting IDF_PATH: C:\Users\Max\Desktop\esp-idf-2
Adding ESP-IDF tools to PATH...
    C:\Users\Max\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin
    C:\Users\Max\.espressif\tools\xtensa-esp32s2-elf\esp-2021r1-8.4.0\xtensa-esp32s2-elf\bin
    C:\Users\Max\.espressif\tools\xtensa-esp32s3-elf\esp-2021r1-8.4.0\xtensa-esp32s3-elf\bin
    C:\Users\Max\.espressif\tools\riscv32-esp-elf\esp-2021r1-8.4.0\riscv32-esp-elf\bin
    C:\Users\Max\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
    C:\Users\Max\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
    C:\Users\Max\.espressif\tools\cmake\3.16.4\bin
    C:\Users\Max\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\bin
    C:\Users\Max\.espressif\tools\ninja\1.10.2\
    C:\Users\Max\.espressif\tools\idf-exe\1.0.1\
    C:\Users\Max\.espressif\tools\ccache\3.7\
    C:\Users\Max\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
    C:\Users\Max\.espressif\python_env\idf4.3_py3.7_env\Scripts
    C:\Users\Max\Desktop\esp-idf-2\tools
Python requirements from C:\Users\Max\Desktop\esp-idf-2\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
  idf.py build
[1/8] Performing build step for 'bootloader'
ninja: no work to do.
[2/6] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
ccache C:\Users\Max\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -IC:/Users/Max/Desktop/esp-idf-2/components/newlib/platform_include -IC:/Users/Max/Desktop/esp-idf-2/components/freertos/include -IC:/Users/Max/Desktop/esp-idf-2/components/freertos/port/xtensa/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_hw_support/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_hw_support/port/esp32/. -IC:/Users/Max/Desktop/esp-idf-2/components/heap/include -IC:/Users/Max/Desktop/esp-idf-2/components/log/include -IC:/Users/Max/Desktop/esp-idf-2/components/lwip/include/apps -IC:/Users/Max/Desktop/esp-idf-2/components/lwip/include/apps/sntp -IC:/Users/Max/Desktop/esp-idf-2/components/lwip/lwip/src/include -IC:/Users/Max/Desktop/esp-idf-2/components/lwip/port/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/lwip/port/esp32/include/arch -IC:/Users/Max/Desktop/esp-idf-2/components/soc/include -IC:/Users/Max/Desktop/esp-idf-2/components/soc/esp32/. -IC:/Users/Max/Desktop/esp-idf-2/components/soc/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/hal/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/hal/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_rom/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_rom/esp32 -IC:/Users/Max/Desktop/esp-idf-2/components/esp_rom/include/esp32 -IC:/Users/Max/Desktop/esp-idf-2/components/esp_common/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_system/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/driver/include -IC:/Users/Max/Desktop/esp-idf-2/components/driver/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_ringbuf/include -IC:/Users/Max/Desktop/esp-idf-2/components/efuse/include -IC:/Users/Max/Desktop/esp-idf-2/components/efuse/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/xtensa/include -IC:/Users/Max/Desktop/esp-idf-2/components/xtensa/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/espcoredump/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_timer/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_ipc/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_pm/include -IC:/Users/Max/Desktop/esp-idf-2/components/vfs/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_wifi/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_wifi/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_event/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_netif/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_eth/include -IC:/Users/Max/Desktop/esp-idf-2/components/tcpip_adapter/include -IC:/Users/Max/Desktop/esp-idf-2/components/app_trace/include -IC:/Users/Max/Desktop/esp-idf-2/components/mbedtls/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/mbedtls/mbedtls/include -IC:/Users/Max/Desktop/esp-idf-2/components/mbedtls/esp_crt_bundle/include -IC:/Users/Max/Desktop/esp-idf-2/components/app_update/include -IC:/Users/Max/Desktop/esp-idf-2/components/spi_flash/include -IC:/Users/Max/Desktop/esp-idf-2/components/bootloader_support/include -IC:/Users/Max/Desktop/esp-idf-2/components/nvs_flash/include -IC:/Users/Max/Desktop/esp-idf-2/components/pthread/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_gdbstub/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_gdbstub/xtensa -IC:/Users/Max/Desktop/esp-idf-2/components/esp_gdbstub/esp32 -IC:/Users/Max/Desktop/esp-idf-2/components/wpa_supplicant/include -IC:/Users/Max/Desktop/esp-idf-2/components/wpa_supplicant/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/wpa_supplicant/include/esp_supplicant -IC:/Users/Max/Desktop/esp-idf-2/components/perfmon/include -IC:/Users/Max/Desktop/esp-idf-2/components/asio/asio/asio/include -IC:/Users/Max/Desktop/esp-idf-2/components/asio/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/bt/common/osi/include -IC:/Users/Max/Desktop/esp-idf-2/components/bt/include/esp32/include -IC:/Users/Max/Desktop/esp-idf-2/components/bt/common/api/include/api -IC:/Users/Max/Desktop/esp-idf-2/components/bt/common/btc/profile/esp/blufi/include -IC:/Users/Max/Desktop/esp-idf-2/components/bt/common/btc/profile/esp/include -IC:/Users/Max/Desktop/esp-idf-2/components/bt/host/bluedroid/api/include/api -IC:/Users/Max/Desktop/esp-idf-2/components/cbor/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/unity/include -IC:/Users/Max/Desktop/esp-idf-2/components/unity/unity/src -IC:/Users/Max/Desktop/esp-idf-2/components/cmock/CMock/src -IC:/Users/Max/Desktop/esp-idf-2/components/coap/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/coap/port/include/coap -IC:/Users/Max/Desktop/esp-idf-2/components/coap/libcoap/include -IC:/Users/Max/Desktop/esp-idf-2/components/coap/libcoap/include/coap2 -IC:/Users/Max/Desktop/esp-idf-2/components/console -IC:/Users/Max/Desktop/esp-idf-2/components/nghttp/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/nghttp/nghttp2/lib/includes -IC:
/Users/Max/Desktop/esp-idf-2/components/esp-tls -IC:/Users/Max/Desktop/esp-idf-2/components/esp-tls/esp-tls-crypto -IC:/Users/Max/Desktop/esp-idf-2/components/esp_adc_cal/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_hid/include -IC:/Users/Max/Desktop/esp-idf-2/components/tcp_transport/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_http_client/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_http_server/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_https_ota/include -IC:/Users/Max/Desktop/esp-idf-2/components/protobuf-c/protobuf-c -IC:/Users/Max/Desktop/esp-idf-2/components/protocomm/include/common -IC:/Users/Max/Desktop/esp-idf-2/components/protocomm/include/security -IC:/Users/Max/Desktop/esp-idf-2/components/protocomm/include/transports -IC:/Users/Max/Desktop/esp-idf-2/components/mdns/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_local_ctrl/include -IC:/Users/Max/Desktop/esp-idf-2/components/sdmmc/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_serial_slave_link/include -IC:/Users/Max/Desktop/esp-idf-2/components/esp_websocket_client/include -IC:/Users/Max/Desktop/esp-idf-2/components/expat/expat/expat/lib -IC:/Users/Max/Desktop/esp-idf-2/components/expat/port/include -IC:/Users/Max/Desktop/esp-idf-2/components/wear_levelling/include -IC:/Users/Max/Desktop/esp-idf-2/components/fatfs/diskio -IC:/Users/Max/Desktop/esp-idf-2/components/fatfs/vfs -IC:/Users/Max/Desktop/esp-idf-2/components/fatfs/src -IC:/Users/Max/Desktop/esp-idf-2/components/freemodbus/common/include -IC:/Users/Max/Desktop/esp-idf-2/components/idf_test/include -IC:/Users/Max/Desktop/esp-idf-2/components/idf_test/include/esp32 -IC:/Users/Max/Desktop/esp-idf-2/components/jsmn/include -IC:/Users/Max/Desktop/esp-idf-2/components/json/cJSON -IC:/Users/Max/Desktop/esp-idf-2/components/libsodium/libsodium/src/libsodium/include -IC:/Users/Max/Desktop/esp-idf-2/components/libsodium/port_include -IC:/Users/Max/Desktop/esp-idf-2/components/mqtt/esp-mqtt/include -IC:/Users/Max/Desktop/esp-idf-2/components/openssl/include -IC:/Users/Max/Desktop/esp-idf-2/components/spiffs/include -IC:/Users/Max/Desktop/esp-idf-2/components/ulp/include -IC:/Users/Max/Desktop/esp-idf-2/components/wifi_provisioning/include -mlongcalls -Wno-frame-address   -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.1-dirty\" -DESP_PLATFORM -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\esp-project.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj   -c ../main/esp-project.c
In file included from ../main/esp-project.c:38:
C:/Users/Max/Desktop/esp-idf-2/components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:110,
                 from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:568,
                 from ../main/esp-project.c:48:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_Float.c:91:6: warning: conflicting types for built-in function '__builtin_isinf_sign' [-Wbuiltin-declaration-mismatch]
 char isinf(float f)
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\includes.c:1512,
                 from ../main/esp-project.c:679:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_UART.c: In function 'FC_CAL_UART_Init_1':
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_UART.c:263:4: warning: #warning "UART channel 1 is used for the debug output, it might be better to use the debug output component or another UART channel." [-Wcpp]
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_UART.c:279:4: warning: #warning "UART channel 1 has remappable functionality but can break programming functionality! Disabled by default in the Flowcode ESP CAL." [-Wcpp]
../main/esp-project.c: In function 'FCD_07da1_cal_i2c1__Prv_TextConsole':
../main/esp-project.c:698:10: warning: unused variable 'FCL_TSTR' [-Wunused-variable]
  MX_CHAR FCL_TSTR[FCLsz_TSTR];
../main/esp-project.c: In function 'FCD_01211_CircularBuffer1__PeekByte':
../main/esp-project.c:1293:12: warning: unused variable 'FCL_TEMP' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_05261_switch_base__ReadState':
../main/esp-project.c:1518:11: warning: variable 'FCL_OLD_SWITCHVAL' set but not used [-Wunused-but-set-variable]
    // .Return = 1
../main/esp-project.c:1517:12: warning: variable 'FCL_DEL_COUNT' set but not used [-Wunused-but-set-variable]
../main/esp-project.c: In function 'FCD_05261_switch_base__WaitUntilHigh':
../main/esp-project.c:1568:11: warning: variable 'FCL_OLD_SWITCHVAL' set but not used [-Wunused-but-set-variable]
../main/esp-project.c:1567:12: warning: variable 'FCL_DEL_COUNT' set but not used [-Wunused-but-set-variable]
    FCL_SWITCHVAL = GET_PORT_PIN(A, 4);
../main/esp-project.c: In function 'FCD_05261_switch_base__WaitUntilLow':
../main/esp-project.c:1619:11: warning: variable 'FCL_OLD_SWITCHVAL' set but not used [-Wunused-but-set-variable]
    #if (0) // 0 == 1
../main/esp-project.c:1618:12: warning: variable 'FCL_DEL_COUNT' set but not used [-Wunused-but-set-variable]
../main/esp-project.c: In function 'FCD_01531_cal_spi__Master_Enable_CS':
../main/esp-project.c:1847:10: warning: unused variable 'FCL_STR' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_01531_cal_spi__Prv_TextConsole':
../main/esp-project.c:1899:10: warning: unused variable 'FCL_TSTR' [-Wunused-variable]
        :  RXData : MX_UINT8
../main/esp-project.c: In function 'FCD_01531_cal_spi__Master_Disable_CS':
../main/esp-project.c:2033:10: warning: unused variable 'FCL_STR' [-Wunused-variable]
     // SS = 1 - CSPolarity
../main/esp-project.c: In function 'FCD_05482_cal_uart__ReceiveByteArray':
../main/esp-project.c:2746:11: warning: unused variable 'FCL_IDX' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_05482_cal_uart__ReceiveString':
../main/esp-project.c:2808:11: warning: unused variable 'FCL_IDX' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_047b2_NEXTION__SendString':
../main/esp-project.c:2875:12: warning: unused variable 'FCL_IDX' [-Wunused-variable]
../main/esp-project.c:2874:12: warning: unused variable 'FCL_LEN' [-Wunused-variable]
  MX_UINT8 FCR_RETVAL;
../main/esp-project.c: In function 'FCD_047b2_NEXTION__ReceiveString':
../main/esp-project.c:4195:12: warning: unused variable 'FCL_RETVAL' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_05481_cal_uart__ReceiveByteArray':
../main/esp-project.c:4990:11: warning: unused variable 'FCL_IDX' [-Wunused-variable]
    goto FCC_ReceiveByteArray_A;
../main/esp-project.c: In function 'FCD_05481_cal_uart__ReceiveString':
../main/esp-project.c:5052:11: warning: unused variable 'FCL_IDX' [-Wunused-variable]
    goto FCC_ReceiveString_A;
../main/esp-project.c: In function 'FCD_047b1_PC__SendString':
../main/esp-project.c:5119:12: warning: unused variable 'FCL_IDX' [-Wunused-variable]
../main/esp-project.c:5118:12: warning: unused variable 'FCL_LEN' [-Wunused-variable]
../main/esp-project.c: In function 'FCD_047b1_PC__ReceiveString':
../main/esp-project.c:6439:12: warning: unused variable 'FCL_RETVAL' [-Wunused-variable]
../main/esp-project.c: In function 'FCM_calc_VM_16bit_time':
../main/esp-project.c:8060:47: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
In file included from C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\internals.c:568,
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:531:85: note: expected 'MX_STRING' {aka 'char *'} but argument is of type 'volatile MX_CHAR *' {aka 'volatile char *'}
 static MX_STRING FCI_FLOAT_TO_STRING(MX_FLOAT Number, MX_UINT8 Precision, MX_STRING String, MX_UINT16 MSZ_String)
../main/esp-project.c: In function 'FCM_CAL':
../main/esp-project.c:8310:29: warning: passing argument 2 of 'FCI_TOSTRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:366:57: note: expected 'MX_STRING' {aka 'char *'} but argument is of type 'volatile MX_CHAR *' {aka 'volatile char *'}
 static MX_STRING FCI_TOSTRING(MX_SLONG iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
../main/esp-project.c:8316:32: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  if (FCV_FLAG1 == 0)
../main/esp-project.c:2871:45: note: expected 'MX_CHAR *' {aka 'char *'} but argument is of type 'volatile MX_CHAR *' {aka 'volatile char *'}
../main/esp-project.c: In function 'FCM_materiale_tubo':
../main/esp-project.c:8399:31: warning: passing argument 2 of 'FCI_TOSTRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:8405:35: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c: In function 'FCM_diagnostica':
../main/esp-project.c:8861:41: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // STRINGA = FloatToString$ (D_TOF_VM,2)
../main/esp-project.c:8867:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // Name: Call Component Macro, Type: Component Macro: NEXTION::SendString(STRINGA)
../main/esp-project.c:8877:41: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   //CALCOLO PULSE WIDTH RATIO VALORE OK SE COMPRESO TRA 0,5 E 0,7
../main/esp-project.c:8883:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   //CALCOLO PWR UP
../main/esp-project.c:8897:40: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   FCD_047b2_NEXTION__SendString(FCV_STRINGA, FCVsz_STRINGA);
../main/esp-project.c:8903:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   FCD_047b2_NEXTION__SendString("\0xFF\0xFF\0xFF", 1);
../main/esp-project.c:8926:37: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   FCD_047b2_NEXTION__SendString("\"", 2);
../main/esp-project.c:8932:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   //CALCOLO AMPIEZZA SEGNALE RICEVUTO
../main/esp-project.c:8952:37: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:8958:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   FCI_FLOAT_TO_STRING(FCV_VDW, 0, FCV_STRINGA, FCVsz_STRINGA);
../main/esp-project.c:8977:35: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // STRINGA = FloatToString$ (T_TOT)
../main/esp-project.c:8983:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:8993:35: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // Name: Call Component Macro, Type: Component Macro: PC::SendString("\n")
../main/esp-project.c:8999:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // T_TEO = ((L_VM / V_F) * 2.0) * 1000000.0
../main/esp-project.c:9013:49: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // Name: Call Component Macro, Type: Component Macro: PC::SendString(STRINGA)
../main/esp-project.c:9039:49: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9065:38: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  } else {
../main/esp-project.c:9071:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c: In function 'FCM_CALCOLO_PORTATA':
../main/esp-project.c:9214:46: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9217:27: warning: passing argument 1 of 'FCD_047b1_PC__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
 #endif // Disabled code
../main/esp-project.c:5115:40: note: expected 'MX_CHAR *' {aka 'char *'} but argument is of type 'volatile MX_CHAR *' {aka 'volatile char *'}
../main/esp-project.c:9227:47: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9230:27: warning: passing argument 1 of 'FCD_047b1_PC__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  // //V_VM = (L_VM / 1.414213) * (D_TOF_VM / (TOF_DW_VM * TOF_UP_VM)) * 1000
../main/esp-project.c:9287:51: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9290:27: warning: passing argument 1 of 'FCD_047b1_PC__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  // Name: Call Component Macro, Type: Component Macro: NEXTION::SendString("\"")
../main/esp-project.c:9304:47: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  //Comment:
../main/esp-project.c:9307:27: warning: passing argument 1 of 'FCD_047b1_PC__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9317:35: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  FCI_FLOAT_TO_STRING(FCV_Q_VM, 4, FCV_STRINGA, FCVsz_STRINGA);
../main/esp-project.c:9323:32: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:9352:35: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
    Use :richiama la pagina di service
../main/esp-project.c:9358:32: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  FCD_047b2_NEXTION__SendString("page service\0xFF\0xFF\0xFF", 13);
../main/esp-project.c: In function 'FCM_configura_P3':
../main/esp-project.c:10299:36: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10330:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  // Name: Punto di connessione, Type: Declare Connection Point: [B]: B
../main/esp-project.c:10340:36: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10346:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
  // Name: Punto di connessione, Type: Declare Connection Point: [A]: A
../main/esp-project.c: In function 'FCM_configura_P2':
../main/esp-project.c:10400:43: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10406:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
     FCD_047b2_NEXTION__SendString("configura_P2.t0.txt=\"Inserzione\"\0xFF\0xFF\0xFF", 33);
../main/esp-project.c: In function 'FCM_configura_P1':
../main/esp-project.c:10663:36: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
   // Name: Calculation, Type: Calculation:
../main/esp-project.c:10669:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10700:39: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10706:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
     break;
../main/esp-project.c:10716:38: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
../main/esp-project.c:10722:33: warning: passing argument 1 of 'FCD_047b2_NEXTION__SendString' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
    case 4:
../main/esp-project.c: In function 'app_main':
../main/esp-project.c:11301:2: error: 'uart1_interrupt_enabled' undeclared (first use in this function); did you mean '_xtos_interrupt_enable'?
 #if 0 // Disabled code
../main/esp-project.c:11301:2: note: each undeclared identifier is reported only once for each function it appears in
At top level:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:873:13: warning: 'FCI_SCOPY' defined but not used [-Wunused-function]
 static void FCI_SCOPY(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:812:13: warning: 'FCI_SHEAD' defined but not used [-Wunused-function]
 static void FCI_SHEAD(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:792:18: warning: 'FCI_STRMOV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRMOV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:768:18: warning: 'FCI_STRREV' defined but not used [-Wunused-function]
 static MX_UINT16 FCI_STRREV(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:595:18: warning: 'FCI_NUMBER_TO_HEX' defined but not used [-Wunused-function]
 static MX_STRING FCI_NUMBER_TO_HEX(MX_ULONG Number, MX_STRING String, MX_UINT16 MSZ_String)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:476:17: warning: 'FCI_COMPARE' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_COMPARE(MX_STRING sSrc1, MX_UINT16 iSrc1_len, MX_STRING sSrc2, MX_UINT16 iSrc2_len, MX_UINT8 iNoCase)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:450:13: warning: 'FCI_TOUPPER' defined but not used [-Wunused-function]
 static void FCI_TOUPPER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:424:13: warning: 'FCI_TOLOWER' defined but not used [-Wunused-function]
 static void FCI_TOLOWER(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:331:10: warning: 'FCI_TOSTRU32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU32(MX_UINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:297:10: warning: 'FCI_TOSTRU16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRU16(MX_UINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:254:10: warning: 'FCI_TOSTRS32' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS32(MX_SINT32 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:211:10: warning: 'FCI_TOSTRS16' defined but not used [-Wunused-function]
 MX_UINT8 FCI_TOSTRS16(MX_SINT16 iSrc1, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:182:18: warning: 'FCI_RIGHTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_RIGHTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:159:18: warning: 'FCI_LEFTSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_LEFTSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:129:18: warning: 'FCI_MIDSTRING' defined but not used [-Wunused-function]
 static MX_STRING FCI_MIDSTRING(MX_STRING sSrc, MX_UINT16 iSrc_len, MX_UINT16 iStart, MX_UINT16 iCount, MX_STRING sDst, MX_UINT16 iDst_len)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_String.c:113:17: warning: 'FCI_GETCHAR' defined but not used [-Wunused-function]
 static MX_UINT8 FCI_GETCHAR(MX_STRING sStr1, MX_UINT16 iStr1_len, MX_UINT16 iPos)
ninja failed with exit code 1
Running ninja in directory c:\users\max\dropbox\fc9\fc9_esp32_as6040\build
Executing "ninja all"...
Build Failed
Autoclose turned off
FINISHED
Has thanked: 214 times
Been thanked: 362 times
Re: ESP32 ERROR COMPILER
The actual error is probably these lines in the output:
Without seeing your program or the C code generated, it is difficult to know what the error is. But it appears to be related to an interrupt icon somewhere in your code that seems to be disabled.
max.tisc
Post by max.tisc »
Hi Steve
thanks for the answer, following the compiler message I also found other errors, now it works, importing the macros from the FC8 project does not import all the parameters set in the old project
Thank you so much
