PIC24FJ512GA606 download error!
Has thanked: 168 times
Been thanked: 279 times
Re: PIC24FJ512GA606 download error!
Ahhhh! It seems like there is a problem with the FCDX file for that chip. In fact, the following 3 device files all point to the wrong target device:
  • 24FJ512GA606.fcdx
  • 24FJ512GA610.fcdx
  • 24FJ512GB606.fcdx
Ben will need to fix these through the update system, but for now you can do this manually by closing Flowcode and then editing the "24FJ512GA606.fcdx" file. This file should be found in the following folder on your PC:
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PIC16\
And near the start of this file, you need to change the following line:
<device name='24FJ512GB610' product='PIC16' cal='PIC16BIT' family='24F' bits='16' >
to this:
<device name='24FJ512GA606' product='PIC16' cal='PIC16BIT' family='24F' bits='16' >
Please let us know if this fixes the problem.
seokgi
Has thanked: 5 times
Been thanked: 7 times
Post by seokgi »
Thank you!
Modified FCDX file.
But it doesn't compile.
Please let me know what I can do.
24FJ512GA606.fcdx
(57.84 KiB) Downloaded 101 times
Auto_Lifting_Lamp_CTL_211228_1-PIC24FJ512GA606.msg.txt
(2.81 KiB) Downloaded 97 times
seokgi
Post by seokgi »
It is also difficult to change the design due to semiconductor supply and demand problems.
There is a lot of urgency from customers.
Please help me.
Has thanked: 513 times
Been thanked: 473 times
Can you post your flowchart, please?
If you want it to remain private, you can PM it to me.
Has thanked: 444 times
Been thanked: 604 times
The problem should now be resolved via the Help -> Library updates.
If you're still having problems then please let us know and we can investigate further.
seokgi
Post by seokgi »
Thank you.
Compiling works fine.
However, some digital ports do not work.
Ok do you know which specific ports are not working for you and are you trying to input or output?
seokgi
Post by seokgi »
There are several ports. I want to know how to set a specific port as input or output.
Input -> B6,B8, B9, B14, B15, F4
Output -> B13,D2, D3, D8,D9, D10, E0, E1, E2,E3, E4, E5, F0, F1, G6, G7
IOC -> D0, D11, F3
Serial Commnication -> B7, B12 D1, D6
Analog Input -> B10(AN10)
I2C_0 -> E6, E7
I2C_1 -> G2, G3
PWEM -> D4
seokgi
Post by seokgi »
Good morning!
Perhaps I need to adjust the register value that controls the digital port. But I have no control over the registers.
If you tell me how to do it, I'll do it.
Help.
thank you.
seokgi
Post by seokgi »
Please teach me how to do it.
So let's do it.
