Components that already worck with ESP32
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
Happy new year to all!
What components do work with the ESP32 chippack?
Now and in the future?
My idea is that most components will work with this chip?
Has thanked: 616 times
Been thanked: 814 times
Re: Components that already worck with ESP32
Most components should work out of the box except components that require tight high speed timings for example the ws2812 led, dht11 and 22 and 1 wire communications. We are working on adding support for these and hopefully they will be available soon.
Has thanked: 839 times
Been thanked: 205 times
Post by jgu1 »
Hi Ben!
And please the Ili9341 too, doesn´t work. ;)
Jorgen
I wonder if the bug reported here is what is causing the ILI9341 display component to fail?
viewtopic.php?p=511#p511
Fingers crossed with the fix I've just pushed it will work correctly now.
Post by jgu1 »
Well ok Ben. I will give it a go this evening, thank´s for info.
Jorgen
The WS2811 component should now work with ESP32. Hopefully other similar timing critical issues will be ironed out soon.
Has thanked: 234 times
Been thanked: 252 times
Thank you for solving the problem from the ws2811 and ESP32
I use the ws2812 and it's working in the hardware very nice.
FC9_M5STACK Modul Atom Matrix.fcfx
(10.29 KiB) Downloaded 1051 times
https://m5stack.com/products/atom-matri ... opment-kit
In the simulation it's not working.
Excellent thanks Stefan,
I think the sim is working but there is a problem colour value 20 works well on the LEDs but on the monitor it's hard to distinguish from black. If you increase the colour intensity then hopefully you will be able to see the sim functioning.
Let me know.
No simulation working with 255.
But the command refresh from ws2812 is missing.
After the update today it's Perfect!
Every thing is working nice with WS2812 LED. Also in the simulation.
