Transfert Program to Taspberry RPI3B and RPI4B
michelhelson
Post by michelhelson »
Hello to everybody,
I am a fan of the Flowcode Softwares, but I have a problem.
Actually, I am in the trial period of Flowcode 9.
I am trying to transfert the Flowcode program to Raspberries.
When I will to build and to compile to the chip (Raspberry), there is a message saying me that the connection is not done.
In the "New Project" phase, I have introduced the IP, but without succes. :roll:
So, is there anybody to explain me the right procedure to follow?
I have also followed the tutorial of Matrix, but this one is a few short in its explinations... :geek:
I thank you for your reply and,
Best regards.
Michel.
Has thanked: 103 times
Been thanked: 302 times
Re: Transfert Program to Taspberry RPI3B and RPI4B
Yes, things to check are:
The IP address of the Pi, and login name and password, set in project config screen.
The Pi and PC need to be on same network/router.
SSH enabled on the Pi, see Raspi-config (as I recall)
michelhelson
I thank you very much for your reply.
Tm
Tomorrow, I shall try your advices.
I shall write to you back as soon as possible.
Best regards.
Michel.
Has thanked: 724 times
Been thanked: 783 times
If you are still stuck after following this tutorial, then I will follow the tutorial to see if it sends a program to the Pi.
