Selecting Component Macros
Revision as of 12:53, 21 August 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: What Is a Macro?</sidebar>
See Component Macro Icon Properties and Simulation Macro Icon Properties
Select a Component Macro and bring up the icon properties, there will then be a list of all available component macros from the components currently being displayed on the Dashboard Panel and System Panel.
Some Component Macros require parameters and return values to function, these may also be used with variables and constants, which allows you to engineer a program to enable interaction with components to create an effective system.
Component Macros are displayed in a list organised in groups of each component and its functions/macros, they are displayed in a tree structure for clear and easy access.
Simulation Macros can also be selected using the same method and serve a similar purpose, the only difference is that these macros are for simulation only and therefore cannot be run on hardware.
