System Panel
The 3D System Panel
The 3D System panel provides a real-world framework on which to load Flowcode components that compliments the 2D panel. It is designed to show the physical representation of real world components during simulation.
Overview
The 3D System Panel is opened by selecting it in the View menu. Unlike the 2D panel, the System Panel is designed to simulate a 3D environment. It is best suited to designing and positioning objects as all aspects of an object can be viewed. Once an object is designed, it is often used in projects via the 2D panel.
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set via the 'Background icon' at the top of the 3D panel.
The 3D System panel has a Controls toolbar running horizontally across the top, much like the 2D panel.
Components can be added to the 3D System panel from the Components Ribbon. Then, input devices like switches can be operated to control the progress of the simulation, while output devices, like LEDs show the result.
2D panel or 3D System Panel?
To find out more about the differences between the 2D panel and System panel and also recommendations on how to use the two panels for different types of projects please see the article Choosing your Simulation Panel
Table top
Axis alignment
Hint:
Manipulating objects
Selecting items
They can then be grouped:
  • By clicking on the 'Group' icon.
Multiple views
A powerful feature of Flowcode is the ability to view the components from several camera angles simultaneously, enabling orthographic design of the system. Up to four views can be shown.
The number of views can be changed by clicking the 'General Options' icon and then clicking on the drop down menu next to the 'Number of views:' option and then selecting a value from 1-4 on the menu.
By clicking on the appropriate arrowheads, you can set up each view as shown below.
Depending on the size and shape of the Systems Panel, the three views may be arranged vertically, instead of horizontally. Drag one edge of the Systems Panel sideways to see this effect.
An example of doing so is given below - notice the positions of the red, green and blue arrows in each:
In the next image, the instrument panel has been rotated:
