System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options.
Table top
Video instructions
There are an array of videos at your disposal to educate you and improve your skills using Flowcode, to get started with the System Panel see the Introduction to the System Panel video for an overview of the fundamental functionality available using the System Panel.
{{#ev:youtube|2VvUSCCc-sE|640}}
Camera control
- Camera controls
- Error creating thumbnail: Unable to save thumbnail to destination
Pan
Rotate
Orbit
- Hold down the Ctrl key and click-drag the mouse to move the camera eye (the position of the camera).
- Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target (the view of the camera).
- Hold down Alt and click anywhere on the panel to move the camera over that point or object (move the camera to the object).
Zoom
Axis alignment
Hint:
Selecting items
They can then be grouped:
- By clicking on the 'Group' icon. Error creating thumbnail: Unable to save thumbnail to destination
Shapes toolbar
Controls toolbar
Moving objects
Move allows you to move the selected object around the work area.
Stretch allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
Scale allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Rotate allows you to rotate an object. After selecting it and clicking on this control, a number of yellow anchors appear on the object. These allow the object to be rotated around different axes. Corner anchors will spin the object.
Controlling the camera
Pan allows the camera to pan left / right / up / down.
Rotate allows the camera to rotate assuming the table top is the ground.
Orbit third allows the camera to rotate without considering the table top.
General Options
Move Through ignores collision by moving through the colliding object and ignoring it completely.
Move Around avoids collision by moving the object around the colliding object. Note: this is the default option set by Flowcode.
Move Over avoids collision by moving the object over the colliding object.
The Align Axis control is used to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated
The first control, 'Tools' allows you to lock movement of objects:
- To the grid,
- To other objects,
- To the table-top
The second control, 'General Options' is used to:
Multiple views
By selecting multiple views in the 'General Options' several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
