API Panel.Position.RotateX
<sidebar>API Contents</sidebar> Rotates the object around the X axis
HANDLE Handle
HANDLE PivotHandle
- An optional position to treat as the origin to rotate around
FLOAT Degrees
- Number of degrees to rotate by
The rotation call allows an object to be rotated around any point in the target objects local X axis. This has the effect of altering the pitch of the object - in terms of an aeroplane this makes the plane climb or bank.
The handle must be a valid handle to a component or position, or a quoted (string) name of an object that can be selected on the panel.
The image to the right shows a cube with it's axis positions identified.
Calling the simulation api Panel.Position.RotateX(MyCube,MyCube,1) will rotate the object in one-degree steps along it's X-axis as shown by the red rotation arc. To rotate the cube in a counter direction simply specify a negative number for the degrees parameter.
The screenshot from Flowcode v6 below shows a cuboid with it's internal axis shown (red is the X-axis line), and also a circle that cuts right through the cuboid's X-axis (see example section below for links to the file) When the program runs the cuboid rotates along it's X axis. Note also incidentally the cuboids axis is also the same as the world axis but this might not always be the case.
See also
- Add to a calculation icon:
::Panel.Position.RotateX(handle, pivothandle, degrees)
Flowcode example file
Download
SIMAPI_Panel_Position_RotateX_v1 and open it in Flowcode v6.
The sample file
SIMAPI Panel Position RotateXYZ rotates a grouped object around its X, Y, and Z axis.
