API Panel.Position.RotateZ
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Rotates the object around the Z axis
Class hierarchy
Panel
Position
RotateZ
HANDLE Handle
HANDLE PivotHandle
An optional position to treat as the origin to rotate around
FLOAT Degrees
Number of degrees to rotate by
The rotation call allows an object to be rotated around any point in the target objects local Z axis. This has the effect of altering the roll of the object - in terms of an aeroplane this makes the plane spin around.
The handle must be a valid handle to a component or position, or a quoted (string) name of an object that can be selected on the panel.
The image to the right shows a cube with it's axis positions identified.
Calling the simulation api Panel.Position.RotateZ(MyCube,MyCube,1) will rotate the object in one-degree steps along it's Z-axis as shown by the blue rotation arc. To rotate the cube in a counter direction simply specify a negative number for the degrees parameter.
The screenshot from Flowcode v6 below shows a cuboid with it's internal axis shown (blue is the Z-axis line), and also a circle that cuts right through the cuboid's Z-axis (see example section below for links to the file) When the program runs the cuboid rotates along it's Z axis.
See also
Object Rotation
Local and World Space
  • Add to a calculation icon:
    ::Panel.Position.RotateZ(handle, pivothandle, degrees)
Flowcode example file
Download SIMAPI_Panel_Position_RotateZ_v1 and open it in Flowcode v6.
The sample file SIMAPI Panel Position RotateXYZ rotates a grouped object around its X, Y, and Z axis.
