Component: Injector (AT) (Test Injectors)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Test Injectors |
Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
Please click here for the component source code: FC_Comp_Source_InjectorAT.fcfx
GSM Example File
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
| UARTBaud | |
| Channel | |
| Rate | |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| UARTReceive | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
