| Author
Matrix TSL
| Version
1.0
| Category
General Input
IO Expander (MCP23017) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23017.fcfx
ReadPort
| Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
| Allows port bits to be modified without effecting other bits, 255 = write full port.
- BYTE
ConfigureInversion
| Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
| Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
| Port pin to read. Range: 0-7
- BYTE
WritePortPin
| Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
| Value to output on the selected pin. Range: 0-1
WritePort
| Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
| Value to write. Range 0-255
ConfigurePullups
| Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
| Reads an 8-bit value from a register on the I/O expander device.
- BYTE
Address
| Register address to write to. Range: 0-15
- BYTE
SetAddress
| Allows the slave address to be overridden to allow multiple modules to be controlled using a single component.
- BYTE
Address
| Range: 0-7
WriteRegister
| Writes an 8-bit value to a register on the I/O expander device.
- BYTE
Address
- BYTE
Value
| Value to write. Range: 0-255
I²C Communications
External Address
| Selects the value of the three address pins for the MCP23S17.
| Channel selection
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Use Reset
API
ReadPort
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
- BYTE
ConfigureInversion
- BYTE
PortA
- BYTE
PortB
ReadPortPin
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
- BYTE
WritePortPin
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
WritePort
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
ConfigurePullups
- BYTE
PortA
- BYTE
PortB
ReadRegister
- BYTE
Address
- BYTE
SetAddress
- BYTE
Address
| Range: 0-7
WriteRegister
- BYTE
Address
- BYTE
Value
I²C Communications
External Address
| Channel selection
Stop Delay
Baud Select
SDA
SCL
Use Reset
API
