System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options (File:Panel Icon GeneralOpts.jpg).
The System Panel has a Shapes toolbar running vertically down the left-hand side, and a Controls toolbar running horizontally across the top.
Table top
Components can be added to the System Panel from the Components Toolbar. Then, input devices like switches can be operated to control the progress of the simulation, while output devices, like LEDs show the result.
Camera control
- Camera controls
- Hold down the control key and click-drag the mouse to move the camera eye.
- Hold down both the control and shift keys and click-drag the mouse to move the camera target.
- Hold down alt and click anywhere on the panel to move the camera over that point or object.
File:Panel Icon Zoom.jpg There is also a zoom facility, operated by pressing the Ctrl key and moving the cursor over the viewpoint icon. Clicking the mouse button in this and dragging downwards causes the view to zoom out. Dragging upwards causes the view to zoom in. The same functionality can be achieved by holding Ctrl and using the mouse wheel.
Axis alignment
Hint:
Selecting items
- By holding down the shift key and then clicking on a number of items, one after the other;
They can then be grouped:
- By clicking on the group icon (File:Panel Icon Group.jpg).
- By selecting the ‘Group’ option from the ‘Selection’ menu which appears when you click the right-hand mouse button.
In this way, complex structures can be assembled from a number of parts. To ungroup, select the object and then click on the same icon.
Shapes toolbar
File:Panel Toolbar Shapes3D.png
Below it is the text icon,used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, it is displayed as “Please change caption.” You can edit the text displayed using the bottom ‘Text’ control on the Properties Panel.
The next fifteen icons allow you to add a variety of shapes - some two-dimensional, others three-dimensional, to the work area. Each takes the colour chosen in the colour selector at the top. Each one can be configured using the Properties Panel, to determine the position, size and rotation of the shape, for example.
Controls toolbar
Moving objects
File:Panel Icon Move.jpg The left-hand end control allows you to move the selected object around the work area.
File:Panel Icon Stretch.jpg Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Panel Icon Resize.jpg The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Controlling the camera
File:Panel Icon CameraPan.jpg The first allows the camera to pan left / right / up / down.
The second allows the camera to rotate assuming the table top is the ground.
The third allows the camera to rotate without considering the table top.
General Options
File:Panel Icon Collision.jpg The next control (show icon) determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other, with respect to the camera view.
File:Panel Icon LocalAlign.jpg The next control is used to align the camera with the selected object.
File:Panel Icon Tools.jpg The first allows you to lock movement of objects:
- To the grid,
- To other objects,
- To the table-top
File:Panel Icon General.jpg
The second is used to:
- Set the resolution, ‘level of detail’, of the display.
= Exercises
- Exercise 4.1 - Setting up the System Panel
- Exercise 4.2 - Adding electronic devices
- Exercise 4.3 - Adding shapes
- Exercise 4.4 - Grouping components
- Exercise 4.5 - Moving a component
- Lateral movement
- Rotation
- Exercise 4.6 - Adding labels
- Exercise 4.7 - Controlling collisions
- Exercise 4.8 - 2D or 3D?
- Exercise 4.9 - Adjusting the camera
- Zooming in and out
- Panning the camera
- Rotating the camera
- Exercise 4.10 - Configuring the System Panel
