Component: Thermistor Template (Sensors)
Jump to navigationJump to search| Author | Matrix |
| Category | Sensors |
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Please click here to download the component source project: FC_Comp_Source_Thermistor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C.
EBM003 Example
GetIntegerTemperature
| GetIntegerTemperature | |
| Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
SetChannel
| SetChannel | |
| Set the ADC Channel | |
| ChannelID | |
GetRealTemperature
| GetRealTemperature | |
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
CalculateTemperature
| CalculateTemperature | |
| Converts the input ADC value and returns the Temperature in tenths of degree C | |
| ADCValue | |
| ADC Reading to be converted | |
GetADCValue
| GetADCValue | |
| Returns the Raw ADC value from the Analogue Channel | |
SetTemperature
