Component: Rectifier (DSP Operators)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Operators |
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
Please click here to download the component source project: FC_Comp_Source_temp/DSP_Rectifier.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_Rectifier.fcfx
ControlRectifier
| ControlRectifier | |
| Enables or disables the rectifier, enabled by default | |
| State | |
| 0=Disable, 1=Enable | |
Rectify
| Rectify | |
| Collects a single value from the input buffer and outputs a rectified version of the value. | |
RectifyArray
| RectifyArray | |
| Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end | |
