Component: Network Communications (Comms: Networking)
| Version | 1.5 |
| Category | Comms: Networking |
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Please click here to download the component source project: FC_Comp_Source_temp/NetworkComms.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/NetworkComms.fcfx
AcceptClose
| AcceptClose | |
| Goes with the AcceptOpen function to close the new thread handle. | |
AcceptOpen
| AcceptOpen | |
| Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0 | |
Connect
| Initialises the network communications component. | |
Listen
| Listen | |
| Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK | |
| Port | |
| Port number to listen on. | |
Receive
Send
SocketClose
| SocketClose | |
| Closes the current socket connection | |
SocketOpen
| SocketOpen | |
| Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK | |
