Exercise - Create an LED Component
- Open a new Flowcode flowchart.
- Make sure that the System Panel and Panel Properties are visible.
- If they are not, then select them in the View menu.
- Click on the hemisphere shape in the Shapes menu and drag one onto the Systems Panel.
- The blue dotted square around it shows that this object is currently selected.
- Right-click and select 'Center all objects' from the menu.
- Change the name of the component to 'LEDcomponent'.
- To do this:
- Find the 'handle' of the component at the top of the Panel Properties.
- Click on the name 'shape' (the default name).
- Change it to 'LEDcomponent'.
- Next, add two properties to the component. To do this, de-select the hemisphere by clicking anywhere outside it in the Systems Panel.
