API DataRecorder.GetSnapshot
Revision as of 14:11, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
GetSnapshot
Gets a block of the output stream with each input sample operated on, returns number of samples read
- HANDLE StreamH
The stream that is to be read
- LONG TimeUS
The time offset to extract the history from, in microseconds
- ULONG TimeStep
The step in microseconds between each sample extracted
- ULONG Samples
The number of samples to extract - this will expand the array
- FLOAT[] Buffer
The buffer to read the sample data into
- ULONG Return
